C1 Carb backfire - NCRS Discussion Boards
C1 Carb backfire
  • John C.
    • September 30, 2001
    • 130
    C1 Carb backfire
    When this happens is it because the timing needs to be advanced? Thanks for any help.
    Re: C1 Carb backfire
    John -
    Could be retarded timing or an inadequate accelerator pump shot causing a temporary lean "hole" in the transition from the idle system to the main system. Under what specific conditions do you get a backfire?
    • John C.
      • 130
      On a cold start
      • William C.
        • May 31, 1975
        • 6037
        Is the choke set correctly to full closed, and does the pulloff action meet the factory spec? Lean when cold will cause a backfire and the gradual control of the opening of the choke is designed to combat this. I assume you have the initial timing set to at least the factory specified advance.
        Bill Clupper #618
        • Verne Frantz
          A pop through the carb is more a symptom of too much timing advance, rather than not enough. That applies when you're cranking the engine or stabbing it from an idle.
