ashamed to ask this question but i've been going thru the parts books and shop manuals for an hour now and i'll be durned if i can find the location of the coolant temp sensor on a LT5 engine. hookin it up to the temp gauge and ole Willy will closer to completion. thanks guys, mike
i'm ashamed
Re: i'm ashamed
Mike-----
I've got bad news for you. The LT5 engine coolant sensors are located UNDER the intake plenum. So, the plenum has to be removed to access them. There are TWO sensors-----one is for the dash gauge reading and the other is for the ECM.
The sensors are side-by-side; the ECM sensor is the forwardmost and the gauge sensor is behind it.In Appreciation of John Hinckley- Top
Re: i'm ashamed
Mike-----
Somehow or another, I came to be aware of this some time ago, probably via discussion with someone. However, I was able to confirm my recollection by referring to section 6E3-C1 (VIN J) of the 1992 Corvette Service Manual.In Appreciation of John Hinckley- Top
If you'd have just stuck a 572 in the sucker...
...you wouldn't have to ask all these stupid questions... I'm not that crazy about Holley's, but I can kind'a fix one. Nobody can fix a cornputer. If its broke, Ya put it in the landfill. Your bud, Dipstick... Have a Beast on me...- Top
