Temperature Gauge Problem - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    Working the bugs out of the 63. Today the temperature gauge stop woprking. The gauge had been working fine. It stays to the left and will not move to the right as the engine heats up. The gauge will go to center when the engine is shut off and return to the left as soon as thr key is turned on.
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Terry D.
    • May 31, 1987
    • 2690
    Re: Temperature Gauge Problem
    Try the simple things first, trace the wires to make sure no breakage, grounded etc, then try new sending unit. Those with more knowledge will be able to add to this.
