I would like some advice from those of you who have replaced the rear spring cushions on your cars...... I need to replace all the hardware and the two rubber cushions at each end of the spring, since the originals on my '64 are cracked and crumbling. I plan on placing a screw jack under each end of the spring and raise it up slightly to relieve any downward presssure that may exist from the flexing spring. Then, remove the existing bolt and cushions and replace them.
Am I missing any other steps....? It appears to be a fairly straight forward job, but I am not sure....
Any comments are appreciated....
Garry
Garry
