A handy tip when installing the seat belts. Use an awl to locate the holes that the anchor bolts go in. Once you have that awl poking through through the carpet, take a pencil style soldering iron and make you hole in the carpet. The nice thing about using the pencil point soldering iron is that you leave a clean hole without any loose threads to catch or snag. It melts the nylon of the carpet and makes a perfect fit for the bolt.
Gary
Gary
