Re: i would think that any water in the fuel would - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Clem, As you stated water and aluminum don't mix at all. I see FI baseplates or intakes that have so much corrosion and it's from water and dampness. Water in the fuel bowl does a number on the inside of the casting but so does some of the fuels. I can always tell when the owner is running corn fuel because it makes a big mess. Meanwhile LL100 forever. Haven't called you Smokey Clem for a long time have I. Remember who gave you that name? John
  • Clem Z.
    • January 1, 2006
    • 9427
    john the water ends up at the lowest point
    so it is in direct contact with the metal at all times.
