Starter Shims? - NCRS Discussion Boards
Starter Shims?
  • Everett Ogilvie
    Starter Shims?
    What are the symptoms if starter shims are needed? Assume a brand new rebuilt starter, and putting it on for the first time. Does one start with no shims first? Then what? If it engages and disengage fine, no worries?
  • George Daina
    Ungodly starter noise....
    when it meshes with the flywheel, beat up & chewed flywheel teeth is a sign that tells you "shims, brother, give me shims".
