1961 fuse problem I broke down - NCRS Discussion Boards
  • Ron Gaal
    and went to Canadian Tire and bought fuses they don't work!
    its kind of a coincidence that the brake,interior lite and dash lites go out at the same time. Please advize as to my next move. Thanks
  • Rob Dame
    Re: 1961 fuse problem I broke down
    I thought you were gonna break down and buy a test light. Do they share a common ground? Rob
    • William C.
      • May 31, 1975
      • 6037
      You are now back to the issue of do you have a power delivery problem between the battery and the fuseblock, or between the fuse and the feed to the switches. Knowing that (IE the test light) will start you on the next step, finding and fixing the problem. Electrical problems are primarily small steps of isolating parts of the circuit and stepping thru the isolated sections to find the problem, no easy outs, and no short-cuts.
      Bill Clupper #618
      • Ron Gaal
        I did buy a test light but the ground cord is not long enough to reach the frame
        I would not no were to begin to look for a common ground!!
        • Ron Gaal
          got the interior dash lights working
          the brake and tail lights still not working...to get the others to work I took the fuseout and put back in can there be abit o corrosion on thfuse block clips that hold the fuse in??
          • William C.
            • May 31, 1975
            • 6037
            Re: got the interior dash lights working
            Yes, that was one of the reasons for the test light.
            Bill Clupper #618
            • Rob Dame
              Clip the end of the test light to the radio case
              • William C.
                • May 31, 1975
                • 6037
                YOu have a 5 amp and a 15 amp fuse in the lighting circuits. Clean the contacts that hold the 15 amp fuse and see where you are.
                Bill Clupper #618
                • Terry R.
                  • March 1, 2005
                  • 359
                  Their is a black ground wire on one of the attaching screws for the gauge housings. Terry Robertson
                  • Larry S.
                    • August 31, 2000
                    • 356
                    Don't get mad,or insulted.
                    But I think if your having troubles finding a ground for the test light you may be better served finding a vette shop to diagnose your problem and repair it,
                    The electrical system in our cars has grounds all over the place,and if one of the grounds are bad it will also cause problems.
                    When I am trouble shooting an electrical problem one of the first things I check is the grounds take them off clean them and reconnect them. then I go after the live feeds.
                    Also the electrical system is not protected like a new car with a fuse-able link on the main power supply. I say this because over the years I have heard many horror story's of a C1 vette burning up because of NON fused circuits getting shorts. Just recently some one sent me a link to a story of a fellow out for a drive and his engine wires started to smoke,He pulled over to see what was going on,turned the car off but left it in gear (we all do that dont we) only to have the wires burn together between power and the starter solenoid and the car was trying to start as it was cranking down the road.
                    You can also purchase a wiring diagram for the car to help you trace out the wires. There is a fellow named Don Olson who sells colored wiring diagrams they are real easy to follow.
                    Best of luck with it
