A friend has a set of 5 KO's + hardware that appear (IMO) to be original, but with the following deviations from side-by-side comparison with my '66 factory rim. His wheel back side has the 24 mould injection points, as stock, and the slightly raised (flat) pad oval in which you'd normally expect to see the K-H and D-49986 embossed is completely blank. The original cast surface and edge flash is still there (ie nothing ground off). There are no date stamps, which, if original, would place them sometime prior to early '65. Of course, there are no "Western" or any other repro markings. The front side of the wheel is exactly like my original, including vane width, outer rim depth and x-section, etc.
The spinners are bone stock, with all "behind the ear" markings as expected.
The adaptors appear original in all forged and machined surfaces (again, side-by-side comparison with mine) with the following exception. About 2" inside the cone, looking in from the flange towards the thread end, where, on the edge of a stepped diameter change, there is normally the debossed D-49xxx (can't read mine completely), his adaptor is machined (in a lathe, not ground off) to (IMO) remove all evidence of the K-H markings in this location. Now this is weird, as 90% of original KO owners are not even aware that these markings exist (including me, until about 6 months ago; thanks NDB).
My obvious question(s): Has anyone seen this before ? Are they factory K-H but pre-release ? Was there anyone re-popping KO wheels (at least more than 10 years ago) from original moulds ?
