1980 Differential Date Code Location - NCRS Discussion Boards
  • Pete Zietzke
    I'm having trouble in finding the precise location where the assembly date code is stamped into the differential assembly unit.
    As best I can tell the code is either underneath the rear spring/center mount plate or the strut rods metal piece that they connect to.
    Either place will require disassembly of components to gain visual access ... something I'm not inclined to perform unless absolutely necessary.
    Please advise as to the best method to determine actual stamped code.
    Best Regards,
    Pete
    Re: 1980 Differential Date Code Location
    Pete -
    You don't have to remove anything - the ratio/assembly code is stamped on the bottom flange of the diff housing, BETWEEN the spring retaining plate and the camber strut rod bracket. Will require some cleaning to see the characters.
