diff. between 59 60 - NCRS Discussion Boards
diff. between 59 60
  • Paul Bowers
    diff. between 59 60
    just wondering
    what are the differences between 1959 and 60 vett
    thanks
    paul
  • William C.
    • May 31, 1975
    • 6037
    Re: diff. between 59 60
    Seat and door panel patterns, Trim around the radio speaker on '69, not on '59, differences in Fuel injection systems if equipped, I believe the rear sway bar was a '60 piece, not '59 but I'd have to check the AIM on that one.
    Bill Clupper #618
    • Mike E.
      • February 28, 1975
      • 5134
      Also, 59 tach background all black, 60 backround with colors
      • Paul Bowers
        thanks
        bill and mike just wondering
        paul
        • Tom H.
          • January 1, 2001
          • 77
          Just a few more differences between 59 and 60, needles on gauges blunt 59 pointed 60. pass corvette cove has blue and red bars in 60 none in 59, yes sway bar was on 60 not 59, T3 headlights are high guide 59 low guide 60, hood latches female different design from 59 to 60 and serial number is welded to the steering column 60 ,in drivers door jam 59. Tom
          • Anthony F.
            • December 1, 1985
            • 191
            A couple more are the door end caps. 59 smooth with screw & 60 raised inner edge with screw. 59 shifter knob and door release wher white 60's were black.
            59 dash end caps where a flat stainless steel piece while 60's where a painted cap.
            • don izzo
              are you sure the sixty nobs where black. my nos that came in the box with the car are white.
              Don
              • Russ U.
                • April 1, 2004
                • 345
                One more for you....
                The wheels on a 59 were painted black. The wheels on a 60 were painted body color.
                Russ
                • John M.
                  • January 1, 1999
                  • 1553
                  Hood is different too. *NM*
                  • Wayne P.
                    • August 31, 1975
                    • 1025
                    Re: Hood is different too.
                    Did you guys miss the most obvious seat pattern of vertical pleats vs horizontal? That's the one I always look for. Easy to spot!
