C2 Fuel Tank Filler Center
Re: C2 Fuel Tank Filler Center
Loosen the tank straps all the way - push bolt up and out of cross member support. At this point tank is free to move around (low gas level please). If your tank has been in a long time it may have attached itself to frame members, but it is not bolted so it will move. Caution, watch the wring to sending unit (disconnect it).- Top
