62 Power Top Assembly - NCRS Discussion Boards
  • Richard H.
    • January 1, 1999
    • 32
    Does anyone know where I can find reference material for a 62 Power Top Assembly? Also, are all c1 assemblies correct for the 62, or is there a particular model only associated with this year. Thank so much. Deb
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 62 Power Top Assembly
    58 to 62 are all the same , 56 different by it's self, 57 different by it's self
    But many parts are interchangable but not all! 56 frame is all by it's self
    • Joseph T.
      • April 30, 1976
      • 2074
      Check the assembly instruction manual AIM for your 62..normally there is a fairly detailed drawing of the contraption!
      Experts on these systems are few and far between..but guys like Roy who have worked on them should be able to help.
      Joe
      • Richard H.
        • January 1, 1999
        • 32
        Thank you, Roy. This helps a great deal. My car is a power top car, but of course, the assembly is not there. The holes are in the trunk where the assembly should go and some very limited wiring. I just wanted to be sure if I ever found an assembly for another year that it would be correct for my car. I am trying to put this car back to original as much as possible. Thanks again for the info. I'm sure I'll have many more questions. Deb
        • Richard H.
          • January 1, 1999
          • 32
          Joe: I did see an assembly diagram in the AIM. Now I have the task of finding a unit. I have seen parts on ebay but have never been sure whether these were the correct ones. This will be an eventful search, I am sure. Thanks again for the advice. Deb
