Two questions! 1. Has anyone tried to replace a gauge in the cluster without removing the cluster? In this case it is the amp gauge and on the outboard side. Since it is rare to get it all back intact could the gauge be R/R if the right side dash pad was removed and working through the area now exposed? 2. On a deluxe interior door panel, has anyone had experience with repairing the wood insert? This insert is a "parchment grade" wood and very thin, it tends to dry out and get hairline cracks in the direction of the grain. These small cracks raise slightly and are noticeable to the touch. The repros are not wood at all but are formica and much different in appearance. All help and suggestions appreciated, Thanks, Bill #20328
