Something has bothered me deeply, usually while in the bathroom, or during intimate moments with my lady friend, and that's the moral ramifications of stamping an engine pad. I mean STAMPING. Not RESTAMPING. I've seen otherwise major cool judging dudes go ballistic over restamped pads! So if you STAMP one, you can truthfully say that you didn't RESTAMP it. (not unless you hit it twice or more times.) Consider a blank generator tag. You STAMP it and it's an acceptable part of restoration. If you RESTAMPED it, then what is it? A fraud? A counterfit? If it appears as an original then things are fine. Are things fine if your engine pad appears as original? If it's undetectable as a restamp then it's "original"! Is it? Is this right? or is this wrong?
Suppose you find an 870 engine block with only the Flint assy date stamped on it with only an "R" as half of the suffix. I have bought bunches of such blocks over the years. Now you can stamp a vin derivative on an unaltered pad and add the second letter of the suffix to create one of several legitimate usage codes out of the Flint assy date. Here we have taken a used unaltered block and turned it into an acceptable "original" engine. Is this right? Is this wrong? If you claim the engine is original and profit from that claim then you have commited a fraud. If you take an oath that the engine was NOT RESTAMPED then you are legally in the right as long as no claim of originality is made. Is this right or wrong?
It is a very short hop to find the "clean Pad" block and do your thing. Hey when you bought the block there was nothing on the pad, right? You didn't remove any numbers. How much further is it to actually remove the numbers and stamp in you own.
I hope you Corvette men and women can help me through this so I can have a better sex life!
Varooooooooooooooooooooooooooooooooooooooooooooooo oooom!
