what is the correct procedure to remove the dash closter from a 1960
c1 dash cluster
Re: c1 dash cluster
Greg
Suggest you either buy a copy of the ST-12 service manual or go to the local library and look at their copy. There are several sections pertaining to removing the instruments and the housing itself. It woulf take forever to type it all out for you. The manual also has pictures to help with install and uninstall.
Terry- Top
