Vent window frame Help needed - NCRS Discussion Boards
  • John S.
    • July 31, 1990
    • 292
    How can I tell the difference between the coupe and conv. vent window stainless. Is it the length of the shaft that goes down to the crank regulator? If so does any one have those demensions? Thanks for any help john
  • Peter L.
    • May 31, 1983
    • 1930
    Re: Vent window frame Help needed
    John - What year car? Pete
    • John S.
      • July 31, 1990
      • 292
      My question is for midyears. The parts book says 1963-67 coupe and conv. take different vent window frames, the stainless piece the window sets in. My question is what is the difference in the two. thanks for help john
      • Peter L.
        • May 31, 1983
        • 1930
        John - The pivot piece on the outside front of vent window frame on the coupe is a small "L" shaped bracket with a hole for the pivot rivet and on the conv the bracket has a pivot post. Pete
        • John S.
          • July 31, 1990
          • 292
          Right on. Thanks I should have known that one. Thanks again
