c1 exhaust system - NCRS Discussion Boards
c1 exhaust system
  • Howard M.
    • June 30, 2000
    • 124
    c1 exhaust system
    Hi all:
    Just wondering if the front exhaust pipes on a '60 base engine can be removed and replaced without pulling the exhaust manifolds. I really don't want to take apart more than I have to. Thanks
  • Don H.
    • December 1, 1981
    • 1482
    Re: c1 exhaust system
    You can replace the front pipe without pulling the exhaust manifold. That is if the nuts come off and leave the manifold studs intact. Your biggest challenge will be the next pipe if you are not installing the entire system. Good luck, Don H.
