C2 dimmer switch - NCRS Discussion Boards
C2 dimmer switch
  • Jeremy Hedges
    C2 dimmer switch
    I am using my original dimmer switch, it turns on the low beam/ high beam lights just like it should, but the dash indicator is on all the time. I tried a repo switch and now it is never on. Everything is hooked up correctly. New bulbs installed. What could be the problem?
    Jeremy Hedges #31711
  • Randy S.
    • January 1, 2003
    • 586
    Re: C2 dimmer switch
    Jeremy,
    You sure you have the right bulb socket plugged into the cluster hole. Should be 20ga light green wire with 1445 bulb for high beam. Green wire comes from dimmer switch
    Randy
