67 lower panel reinforcement asm. - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    Please refer to section UPC 11-13, page B3. Does the lower half of item no. 8, the reinforcement asm, point forward or to the rear?
    Thank you.
    Randy
  • Phil P.
    • April 1, 2006
    • 409
    towards the front.
    #9 is a phillips pan head screw i think 1/4 20---the empty hole will get a bolt through it and the core support which will screw into the upper panel support rod which has a welded square nut affixed to the support rod---good luck
