69 side exhaust rocker panel cut out - NCRS Discussion Boards
  • Mike Lesher
    The installation instructions with my 1969 GM repro side exhaust give detailed measurements for the rocker cut out. The drawing has a shaded area that isn't very clear on what the final cut out should look like though. The drawing appears to be a copy of the assembly manual page dealing with the side exhaust. Does anyone have a photo of the cut out that they would post?
    The drawing also shows a shaded strip of fiberglass on the bottom of the rocker panel the entire length from the leading edge of the door to the rear wheel opening. Does this area get cut out also or just the area behind the front wheel opening?
    All help is appreciated! I don't want to be cutting more 'glass than I should be cutting.
    Mike
