I don't seem to be able to resolve this. The car has a NOM 350 in it right now. It will at times just die, either at idle or while driving. I'm not getting any spark from the coil wire when this happens, it will crank fine, just won't fire. Previously, I jumpered across the ballast resistor, which seemed to fix the problem, so I purchased and installed a new ballast resistor. Now I'm getting the same symptoms again, and even with the ballast resistor jumpered to get me home, it still cut out a little bit, although perhaps the alligator clips on the wire were jolted around from driving.
Any advice would be appreciated. I've got a new coil, and new ballast resistor. Is my first course of action to just try a new ballast resistor?
thanks
Matt
thanks
Matt
