After a complete rebuild of a '59 283/245 the oil pressure now reads over 60+ lbs. at anything above an idle. At idle, engine hot, it reads about 35-40. Prior to rebuilding the engine the oil pressure was normal. Since this problem surfaced I have done several things....1.attached a mechanical gauge to engine, read the same, pegged at 60#. 2. removed engine, checked for blocked oil passages, didn't find any blockage, had block boiled out. 3. checked all bearing clearances. 4. replaced oil pump with GM #10055849, a standard pump according to the parts guy. 5. replaced the distributor (the car came with a different distributor, I put the original back in during the rebuild. I know it doesn't help but I'm desperate.) 6. changed the oil filter bypass spring.
None of these things made any difference. I have 10w30 oil and have also tried 30w, with no change.
The question I have is there something I have missed that would alter oil pressure?
