My right side low-beam headlight will not come on when the switch is pulled. The driver side low beam and both taillights work fine. When I hit the high beams, both high beams come on and both low-beams light up. I replaced the right side low beam and got the same results, so I'm fairly certain it isn't the headlight.
I'm not sure where to begin, but a little background info may be helpful. Last weekend, I replaced my heater core, which as many of you know requires removal of numerous pieces/parts around and under the dash. This is the second time in 2 years replacing the heater core, so last week went very smooth as I have seen and done it before.
I looked under the dash today in hopes I just knocked a wire loose, but didn't see anything out of sorts.
Anyone seen this problem before or have any advice for troubleshooting this problem.
