65 frame numbers - NCRS Discussion Boards
65 frame numbers
  • Jim R.
    • June 30, 2001
    • 643
    65 frame numbers
    Hi guys i just noticed that now i might have to do my frame numbers over ,i recieved my stencil from LIC for a 65 it is as follows 3871317 above then 303196-4 . i think the numbers after the - should be 20-29 and not 4, i think 4 was used on 1963 frames. so it should read 303196-20 or 21-29 can anyone verify that i am right, and how could they screw up this stencil ,my luck i guess. jim
    JR
  • John S.
    • September 30, 1997
    • 263
    Re: 65 frame numbers
    Jim,
    According to 1965 Judging Guide, this number can be any mumber from 0 to 9.
    • Jim R.
      • June 30, 2001
      • 643
      thats right john but 0-9 has to come after the 2 so -4 cant be, it would have to be 20 21 22 23 24 25 26 27 28 0r 29.so see whatever 0-9 is used it has to come after the 2. or try this, wrong =303196-4 correct would be 303196-20 or 303196-21 or 303196-22 and so on. now if they would have had the 2 before the 4 in the one they sent me that would be ok as it would have been 303196-24 but for some reason they left out the 2 and just went with the 4 and thats not correct for 65. jim.
      JR
      • John S.
        • 263
        Jim,
        You are correct - they sent you a 1963 stencil.
        • Mark S. Lovejoy
          Jim,
          This is from a Quanta '65 kit.
          • Jim R.
            • June 30, 2001
            • 643
            thanks for the help guys .
            JR
