C1 vacuum lines judging?? - NCRS Discussion Boards
  • Las K.
    • July 31, 2006
    • 96
    can't locate any pictorial details for the correct routing of the vacuum lines for a '61 230 H.P. automatic and I'm not sure if this portion is actually judged. I have a 2 piece line coming from the transmition and it appears that they are connected with a "T" which would accept the line from the wiper motor. This is receives vacuum from the back of the carb. The vacuum line from the distributor is then connected to the hollow manifold stud. Any input would be great.
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 vacuum lines judging??
    Try the assembly manual. RPO 313, sheet 7, at least in the 60 manual, also in the 'same section of the '62 manual, but a different configuration is used in '62.
    Bill Clupper #618
