sealants and adhesives - NCRS Discussion Boards
  • DAVE CRAIG
    i have a 72 that i've tore down to the birdcage starting to put back together . had to get a new birdcage i had it sand blasted and powder coated. my two concerns before i get started with the reassembly is what to use to seal or bond the cowl to the birdcage and also the fiberglass pieces that are riveted to hinge pillar what is used to make that seal with todays products thanks
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: sealants and adhesives
    Sealant and adhesive technology has changed considerably since these cars were built, so I don't think anyone can provide you with exact equivalent products today. The important characteristics you want to match, or most likely exceed, are sealing capability, and hardened properties (dries hard, remains flexible, paintable, etc).
    If you go into 3M's product selector (link below; click on "sealants"), there is a plethora of products that are similar in purpose to the original products. Probably for the application you're asking about, 3M's All-Around Autobody Sealant 08500 is as good as any, or possibly some of the heavy-bodied body seam sealers. The 08500 sealant is latex, but they also have seam sealers made from rubber, butyl, nitrile, and epoxy
    Read the descriptions, and pick the properties you want; it helps to know what the sealer you removed was like. I would avoid silicone and probably epoxy. The butyl Strip Calk is used to seal heater boxes to firewall, moldings to body frame, and other places that require a non-hardening sealant.
    3M Product Selector
    • Dick W.
      • 10483
      I believe that 05883 would be a very good 3M choice as would some of the Lords products. I believe that Lords Fusor would be another good product, as well as some of the SEMS products. Maybe Bill Williamson or Wayne Womble will chime in on this
      Dick Whittington
