C1 Kickdown and Cool Off!!!!! - NCRS Discussion Boards
  • steve westphal
    First of all....When I replaced the quadrajet carb on my '56 with the correct 2366SA carb, I can't get the P/G to kick down. I am hoping that it is the wrong kickdown rod, but, we bent it to every dimension possible and still it won't kick down. A repop kick down rod is about $150.00 so I don't want to buy one unless I absolutely have too. I guess I could try it and if it didn't work, get a refund. Any suggestions? Also, any recommendations as to an aftermarket overflow tank for the radiator? Thanks.
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 Kickdown and Cool Off!!!!!
    Hookup a manual kickdown rod that you can activate by hand, and use that to test the kickdown feature. If it won't work manualy activating the rod when applying full throttle, the problem is in the trans, not the linkage.
    Bill Clupper #618
    • Roy B.
      • February 1, 1975
      • 7044
      OK! You have two rods going to the Carb ,
      I.gas rod
      2.trans kick down
      Disconnect the trans rod from the Carb -pull the gas rod> back like a full throttle , pull the trans rod forward all the way, adjust it so that the trans rod just goes into the Carb linkage. You now have set the trans kick down shift. If the trans rod is short you have the wrong rod
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Steve... In my (57) experience, I'd fill the rad..
        ...then run it. Normal thermal expansion would cause the rad to puke coolant for a while. Then it would eventually reach a "happy" level, with no further issues. I finally learned to just leave it at that and had no problems. In essence, the rad was acting as the expansion tank... If I kept trying to "top it off", my efforts would end up on ground... Never had cooling issues with that car. Best, Dennis
        • Tracy C.
          • July 31, 2003
          • 2739
          I'm told the same effect occurs when attempting
          to overfill one's self with Black Jack and Coke. Best to stay at that "Happy" level rather than over indulge and puke it to the ground.
          good to see ya back DC !
          tc
          • Dick W.
            • 10483
            Re: I'm told the same effect occurs when attemptin
            TC, is Dennis's case it is Gentleman Jack straight up! Coca cola gives you a headache
            Dick Whittington
