67 alignment specs - NCRS Discussion Boards
67 alignment specs
  • dave
    67 alignment specs
    Does any one have these specs available for a 4 wheel alignment and does it matter with radials? I feel a lot of rear end sway at highway speeds and all the suspension is O.K.,normal?
    Thanks!
    • 15610
    Re: 67 alignment specs
    Radial tires should run about 1/16" total toe-in. The CSM toe specs are for bias ply tires. It is critically important that the rear toe-in be evenly distributed between each side.
    "Touring" settings at the front are zero camber, and plus 1.2-2.5 degs. caster, with PS in the upper range, if possible.
    Set rear camber at neg. 0.5 deg.
    "Sport" settings with sticky tires are up to -1.0 deg. camber on all four corners and replace the rubber front anti-roll bar link bushings with hard urethane.
    If the car is exhibiting handling anamolies a thorough suspension inspection with particular attention to suspension bushing condition should be accomplished before alignment is attempted.
