68 core support - NCRS Discussion Boards
68 core support
  • Chuck R.
    • April 30, 1999
    • 1434
    68 core support
    I purchased a used replacement core support for my 68 and when I attempted to mount the radiator, I was not able to get the top of the radiator to pull in snug to the support.
    It appears that the support has a slight curve to it.
    Is this "bow" supposed to be there or is the support tweaked?
    I have nothing to go against as the radiator was already out of the original support and it was so shot I could have folded it in half by hand.
    Any feedback would be appreciated.
    Chuck
  • Dick W.
    • 10483
    Re: 68 core support
    I don't have a '68 sitting here to look at, but I think that there is a 3/8"-1/2" gap between the core and the support. It is sealed with a piece of foam
    Dick Whittington
      Re: 68 core support
      Dick and Chuck-----
      Yes, there is a gap at the top with the radiator properly mounted in the "saddle" supports", upper and lower. However, there is no "bow" that I know of with respect to the upper member of the support. In fact, I don't even understand how this member could become bowed.
      • Chuck R.
        • April 30, 1999
        • 1434
        Re: Your right
        I have new foam in place and even then Dick it's just not pulling in nice and clean.
        The more I try to pull it in, the more the retainer and rubber want to slide up and over the mounting hoop on top of the radiator. I don't want to get too burly with the radiator.
        This is really cheezing me off!
        I think I'll lay the core support flat on the driveway and roll over the sucker a couple of times with the ole Dakota
        It's never easy is it?
        Chuckster
        • Geoff C.
          • May 31, 1979
          • 1613
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: My bread is always fresh Geof
            As is my cheese
            The seals are fresh and very plyable. The more I look at it, the more I feel that the board theory may come into play for the core support.
            I was more curious Geof if the core support was a straight arrow or if it does indeed have a slight curviture to it. I can't believe that it would simply because you can't bend the radiator to match.
            Thanks Geof,
            Chuck
            • Chuck R.
              • April 30, 1999
              • 1434
              Re: That makes two of us Joe
              But nothings been straight forward on this project other than the engine rebuild. It's been just one little surprise after another.
              All I can "assume" is that it took a front end hit right on the head light bucket area and it pushed everything back on one side taking the support with it.
              I guess my quip about laying it on the driveway and running over it with the truck is more truth than fiction.
              As always, thanks Joe,
              Chuck
