Spraying Color - NCRS Discussion Boards
Spraying Color
  • Donald T.
    • September 30, 2002
    • 1319
    Re: Six complete coats?
    Mike,
    Spraying the entire car with a 50% overlap would be one coat, and not two. I initially painted the car a few months ago, so I may have used more than a gallon of paint, but I can't really remember for sure.
    Color sanding began to show primer in bright light, so I ordered another gallon. The gallon was enough to cover the car with 6 coats, but that does not include jams, wiper grills, headlamp covers, or under the decklid. I'm not color sanding those areas so they did not require more paint. Also, keep in mind that one gallon of paint makes a lot more sprayable product once mixed with the thinner.
    • Mark #28455
      HVLP uses less paint *NM*
      • Randy R.
        • April 2, 2007
        • 39
        Re: Spraying Color
        Don,
        Which catalyst for the DPLF did you use for your sealer -401 or 402?
        • Donald T.
          • 1319
          Re: Spraying Color
          Randy,
          I used the 402 catalyst with the DPLF. I've used both, just no induction period with the 402.
