C2 Fuel Tank Spill Rubber Replacement - NCRS Discussion Boards
  • Brian K.
    • September 19, 2007
    • 174
    ANyone know if this piece can be replaced without tank removal on a 66 Coupe? I am referring to the round rubber piece with the over flow hose.
    Thank you!
    66 Coupe
    66 Convertible
    2022 2LT Coupe
    67 Chevelle SS396
    67 XLCH HD Sportster
    Re: C2 Fuel Tank Spill Rubber Replacement
    Brian -
    Yes, the rubber boot just pulls off over the filler neck; don't "lose" the drain hose when you remove the old boot - it's a pain to thread it back up over the tank if it drops down behind the tank.
