tach on 60 vette - NCRS Discussion Boards
tach on 60 vette
  • Joe C.
    • April 30, 2001
    • 126
    tach on 60 vette
    went to install my tach on my 60 corvette. Everything seemed to check out fine when I checked it out with dash outside of car. when I installed the dash, the tach needle spun around and came off. Obviously it didn't work. Did I install wrong? what could have caused this tach to not wrong properl? Any suggestions any suggestions how to install proI perly. thanks.
    Re: tach on 60 vette
    Sounds like the pointer needle was loose on the tach's drive shaft... Should take a rather hard/firm push to get it seated.
    • Joe C.
      • April 30, 2001
      • 126
      thanks but what would make the tach needle spin around like that? Is there some way the tach needs to be installed? or is it justa loose needle.
