Hi All
This is hard to explain but here goes. On my completely redone 62, I have noticed a weird noise when I let off the gas pedal.Can't hear it while accelerating cause of engine noise. But it sounds like if something is out of round or unbalanced. It's a low muffle type noise that definatly sounds like something is off balanced.I'm thinking it's coming from the bellhousing area. Pressure plate, clutch etc. Everything is new and the original flywheel was resurfaced. Any thoughts? I was told it could possibly be a broken spring on the clutch disk or the pessure plate. Your help is greatly needed and appreciated before I tear into this. (The noise is not coming from the engine..Only when i'm moving and letting off the gas is when I hear it.)
Thank you....John
Thank you....John
