Remove tight '65 PB Master Cylinder Caps - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 341
    Hello,
    I bought a break fluid tester in order to check the condition of the break fluid. The caps of my '65 Corvette (PB) are very tight. Since I don't know how much applied force they can sustain I'd like to ask for a trick how to remove them ... before breaking them. Thanks in advance.
    Regards
    Oliver
  • Rob A.
    • December 1, 1991
    • 2126
    Re: Remove tight '65 PB Master Cylinder Caps
    Oliver,
    Try rocking the car to get the brake fluid up into the threads a bit...it makes a good lubricant to help get the caps off. Or..try some pure silicone lubricant spray around the outside edges of the caps
    • Geoff C.
      • May 31, 1979
      • 1613
      channel lock & a rag *NM*
