C3 Glass date coding - NCRS Discussion Boards
  • Eric F.
    • June 30, 2003
    • 319
    I have differing date codes on my side glass. The driver side is obviously a replacement and I'm having a heck of a time adjusting it to the new soft top. Is there a way to determine if it was intended for a coupe or a convertible by deciphering the numbers? If so, does anyone know how on replacement glass?
    The passenger side glass is marked M74, which the TIMJG states is for a coupe, and it was easy to adjust. I'm wondering if the TIMJG meant to list the M74 code for a convertible and the M75 code for a coupe. Does anyone know?
    Thanks in advance.
  • Warren F.
    • December 1, 1987
    • 1516
    Re: C3 Glass date coding
    Eric,
    Coupe glass on the rear edge is practically straight. Convertible glass rear edge has quite a noticeable angle (forward).
    • Harmon C.
      • August 31, 1994
      • 3228
      Eric
      C-3 coupe glass will not fit a convertible the shape of the top rear on a coupe is 90 degrees. Convertible glass is much more than 90 degrees I would guess at least 110 degrees. Good luck with the adjustment.
      Lyle
      Lyle
