"Ignitor " ignition - revoval of resistor ? - NCRS Discussion Boards
  • John D.
    • December 1, 1979
    • 5507
    Re: "Ignitor " ignition - revoval of resistor ?
    Mark, If you attempt this type of project again you may want to look at the Lectric Limited one wire set up. Once it is installed it is undetectable unless someone peeks into the distributor cap window. Glad you got your problem solved. John
      Mark -
      Can't comment on the source of the "tick", but it's not the resistor - it's out of the circuit, as one end is open.
