C3 Speedometer Cable Needed - NCRS Discussion Boards
  • Christopher J. Bunsey
    I have a 1976 L-82 with the M21. I need a new speedo cable, BUT it must pass judging. Can anyone with knowledge of a "NCRS" approved version help?
    Thanks!
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 Speedometer Cable Needed
    Chris
    I would check the judging manual for a description of the cable. I would look on the judging sheets for a 76 to see if it is listed. If you find nothing in either place most judges will not notice it is a replacement if it looks like your original cable. As an added note NCRS don't approve parts as far as I know. You should be able to use your housing or find a replacement from a corvette salvage yard or a GM replacement if they still sell a part that looks the same.
    Lyle
    Lyle
