I recently replaced the water pump and I think that the brackets that hold the alternator were not sequenced correctly on the stud that holds them and the water pump on. Is the correct sequence first the lower alt. bracket (orange) then the upper bracket (black) and then the stud (with lock washer and fixed nut) followed by the AIR pump bracket and the lock washer and nut? This looks like the sequence in the AIM, but it isn't very clear.
