I'm having problems shifting from 2nd to 3rd. When trans cold it won't shift. After a little driving it will normally shift. Appears that the linkage might require an adjustment. I have the neutral gate tool. However, there is very little room to reach the levers and loosen the jam nuts or even get to the c-spring clips.
Looks like I need to drop the rear trans mount to access the shifter. Any tricks to this otherwise?
Dave K.
Dave K.
