I'm guessing one needs to have a web site address in order to post a photograph. If that's the case, I can't provide the photo I'd hoped to, and so will try to describe the condition of the frame verbally. Except for brakes and exhaust (and possibly shocks), it's all original down there, and although she runs fine, she looks a wee bit scary down under. I would characterize it as moderate surface rust, grease, and road grime. There are some oil-soaked areas where a bad pan gasket allowed oil to coat adjacent portions of the frame, and surplus grease at various joints and grease fittings, and rust. The rust doesn't appear too pitted or deep, but it sure does look like a 40 year old car that's been driven 67,000 miles and never cleaned. My grandfather had an old International Harvester that looked cleaner than this.
I don't want to remove the body, but I do want to clean everything up as nicely as I can. I have the tank sticker for the car in a plastic sleeve in a 3-ring binder. Are there any other frame markings I should try to save before I begin cleaning? Any suggestions on the type of cleaning solutions I should use? Are power washing or steam cleaning viable options?
