Quanta Belt Quandary - NCRS Discussion Boards
  • Joe R.
    • March 1, 2002
    • 1356
    #31
    Re: Quanta Belt Quandary
    Hi Anthony:
    I've had problems with the Quanta belts tossing at 4000+ RPM on my 67 327/300 with A/C and power steering. I have not had time to fully investigate the problem, but one of my theories is that the Quanta belts may be prone to this, expecially the long A/C belt. I'd love to hear if others on this discussion board have had good results with the Quanta belts at high RPM.
    My first experiment was to switch to Gates belts on the alternator and power steering, and no belt at all on the A/C. That holds up fine at high RPM, but I have not yet tried adding a Gates A/C belt. I'm also looking into converting to the "deep groove" pulleys used on the L79, but that turns out to be a complicated problem because the deep groove pulleys do not line up properly on an A/C car.
    In my research on this problem many people have emphasized that mis-alignment of the pulleys can cause belts to come off. The alignment on my pulleys *looks* fine, but I plan to do some detailed measurements to check it more carefully.
    Also, many people say that one a belt has come off, it may be distorted and should not be reused.
    Lastly, regarding your experience with the alternator belt stretching to the end of the adjustment range, I had this problem too with two successive Quanta alternator belts of the correct part number. I called Quanta and they were very helpful in identifying a slightly shorter belt with similar construction. The best fit was with a belt that was only one inch shorter than the "correct" belt. I was surprised that such a small change in the length of the belt had such a large effect on the position of the alternator adjustment.
    • Kent K.
      • December 1, 1982
      • 1139
      #32
      Joe,
      I put Quanta's belts on my '67 327/300 AC Corvette in January 1994 and still running them with only about 800 miles so far since restoration. All pulleys are original and align perfectly. My '67 will, if it starts as usual, be used in the advanced judging at Old Town. Hope to see you there.
      Regards, Kent Keech
      Kent
      NCM Founder - Member #718
      • Kent K.
        • December 1, 1982
        • 1139
        #33
        Joe,
        Regards, Kent Keech
        Kent
        • Kirk McHugh
          #34
          Interesting because that would be around about the time I got mine, and sounds exactly like the problem I had. I think I just got a "different" Quanta belt that ended up being the correct length, but I don't believe it was numbered and dated correctly. Seems I need to contact Quanta and double check on this. Thanks for the info.
          Kirk
          • Kirk McHugh
            #35
            Kirk
            • Dale S.
              • November 12, 2007
              • 1224
              #36
              I think that wrapped belts should be used for show or judging only. I remember having Gates wrapped belts( mid 1960's, before cut belts) turning over in the pulley's. I was a traveling salesman for an automotive warehouse. We always carried spare belts. This is why they went to the trouble of making deep grove pulleys for SHP cars. This was not uncommon especially at my dragstrip. There is a reason they quit making wrapped belts. I am sure I will get some disagreement on this, but I am just using my experience on this. I run Napa cut belts( Which are Gates belts) on my car and change them for pictures or car shows.Thanks for listening. Dale
              • Dale S.
                • November 12, 2007
                • 1224
                #37
                • Kirk McHugh
                  #38
                  Ran my Quanta belts all this Spring and Summer and never had a slip. Took a long trip early this summer down to the Corvette Museum and they did just fine. I too have a 67 327/300 hp with power steering and AC.
                  • Kirk McHugh
                    #39
                    • Anthony S.
                      • April 3, 2008
                      • 183
                      #40
                      Thanks everyone, I appreciate the comments.
                      It seems 50/50 as to who had problems & who did not. The good news is that Quanta's customer service is very helpful.
                      As for the alternator belt, I think the one I have is the wrong part #(3861946), so I'll probably try the 3847710 belt next, it seems more like the proper application.
                      Just to be safe, I'll do what Quanta asked measure the distance around the pulleys to see what belt might fit better. I've been so busy lately, I haven't had th energy to pull the cover off of the car.
                      Thanks again,,,,,,,,,,,,updates to follow.
                      Anthony
                      Now I have to start a new thread to answer some nut & bolt questions.
                      • Anthony S.
                        • April 3, 2008
                        • 183
                        #41
                        Anthony
                        • Henry S.
                          • April 30, 2005
                          • 816
                          #42
                          Uh-Oh,
                          I have a 67 327/300, no PS or AC I'm restoring. The belt I got (either from L.I. or Quanta, you know CRS) is too short. To get the belt on I had to have the alternator up against the valve cover. I didn't think it was the right one but I was in the middle of other stuff so I forgot about it until now. Anyway looks like I have a couple more calls to make tomorrow.
                          Shooter
                          • Henry S.
                            • April 30, 2005
                            • 816
                            #43
                            Uh-Oh,
                            Shooter
                            • Bill S.
                              • January 31, 2007
                              • 396
                              #44
                              i ran into this 8 mnths ago on my 66 427 L72 took 3 to get the right one. Paragon was really great about it. sent 2 to try. kept one and returned the other with no issues.
                              • Bill S.
                                • January 31, 2007
                                • 396
                                #45
