MC Assy Casting#5480346 - NCRS Discussion Boards
  • George D.
    • August 31, 2000
    • 225
    This AC Delco Master Cylinder assembly was on my 1969 without power brakes. I would like to know what is is supposed to fit. It doesn't have the bleeder screws by the fittings. I found an article in Corvette Fever which says it fits a 67 with the J56 option. Is this correct and what is the value.
    Re: MC Assy Casting#5480346
    George-----
    GM casting #5480346 is a 1-1/8" bore master cylinder and it was used for 1967 applications with J-56. However, it was also used for all 1968-76 applications with J-50 power brakes or J-56 HD power brakes. All 1967-72 applications, PRODUCTION and SERVICE, in which this casting was used had bleeder valves installed on the master cylinder. Consequently, the one that you have is a 73+ version. These are not particularly rare but it is probably worth about $50-100. Your car with manual brakes should have a 1" bore master cylinder, so the one that you have is not even functionally correct.
    • Brandon K.
      • April 1, 1997
      • 474
      The number is correct for a 67 w. J56, but it should have bleeders above the line connections on the left side.
      • George D.
        • August 31, 2000
        • 225
        Thanks, but no bleeder screws
        However, this one doesn't have the blleder screws. Any ideas.
