Seat Track Rollers on 61 Vette - NCRS Discussion Boards
  • Charles C.
    • May 31, 1978
    • 65
    Could you assist on two questions on seats for my 61 Vette:
    1) There is a roller captured between the upper and lower slides of the seat track on a 61-62 Vette seat. The Corvette Central catalogue says there are "4 roller assemblies per seat". My upper track only has only one opening per seat track side (through which I believe the roller protrudes) - meaning there would only be 2 roller assemblies per seat.
    Are there 2 or 4 roller assemblies per seat?
    2) When you assemble the bottom seat cushion assembly to the back seat cushion assembly, does the triangle metal brace on the outboard side of the base frame go under the seat cover vinyl (this vinyl is on the back cushion assembly) or does it go over the cushion vinyl? This question would be answered by whether on the outboard side of the seat, you can see (or cannot see) the metal triangular brace that is on the outboard side of the base frame.
    Thanks for your help.
    Charles
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: Seat Track Rollers on 61 Vette
    Charles...
    Each roller wheel/cage assembly includes one wheel, 1 cage, and 2 ball bearings. A total of 8 roller wheel/cage assemblies are used per car. (2 seats)
    The Trangle brace is exposed...the bottom seat covers just the tip of the brace and the seat back covers down on the brace a little more, leaving much of the side exposed...hope this helps...
