FLEA BAY 67. - NCRS Discussion Boards
FLEA BAY 67.
  • Richard S.
    • November 1, 1994
    • 809
    FLEA BAY 67.
    Check out the Tank Sticker on this sucker....67 Corvette....for over 200 large......
    FLEA BAY ITEM NO: 290201004929.
  • Chris L.
    • November 1, 1998
    • 273
    Re: FLEA BAY 67.
    Rick..please educate me as to what is wrong with this. I see the window sticker shows a 390 and the tank sticker shows 400. What am I missing here? Thanks
    • Anthony S.
      • April 3, 2008
      • 183
      Re: FLEA BAY 67.
      Chris,
      Look further down on the tank sticker & on the bottom of the window sticker where it reads RPO L-68 Convert 390HP to 400HP.
      The 400 HP tri power setup is essentially an "upgrade" from the 390 P L-36.
      I could be wrong, but you couldnt get A/C or power brakes with the 435 HP L-71/L-89 motor. If you really wanted the tri-power setup with these options, your only option was the L-68.
      Anthony
      • Jack W.
        • August 31, 2000
        • 358
        Re: FLEA BAY 67.
        there are more than just a few things wrong with that tank sticker . . .
        • Kent K.
          • December 1, 1982
          • 1139
          Re: FLEA BAY 67.
          Anthony,
          I have a one previous owner 1969 427/435 with power steering and power brakes. It is true that you could not get A/C with the 435 HP in 1967 thru 1969, but you could order it with the 400 HP engine option.
          Kent
          Kent
          NCM Founder - Member #718
          • Chris L.
            • November 1, 1998
            • 273
            Re: FLEA BAY 67.
            I did see that and thought I had seen that on other 400HP cars tank stickers that were legit. Was a 400HP car listed on the tank sticker as a 390 and then at the bottom the 400HP was added?
            • Mike M.
              • May 31, 1974
              • 8365
              Re: FLEA BAY 67.
              yes. mike
              • Tom D.
                • September 30, 1981
                • 2126
                Headrest bench seat? Is that legit? *NM*
                https://MichiganNCRS.org
                Michigan Chapter
                Tom Dingman
                • Brett H.
                  • January 1, 1996
                  • 367
                  Re: FLEA BAY 67.
                  Couldn't get 370 HD posi with AC on the L68 either. I used to have one.
                  Fakes galore!!!!!!!!!!!
                  • John C.
                    • January 1, 2005
                    • 616
                    Re: Headrest bench seat? Is that legit?
                    As strange as that might sound it was how headrests were listed on the tank sheet.
                    • Kenneth B.
                      • August 31, 1984
                      • 2084
                      Re: FLEA BAY 67.
                      The side exaust was the wrong code. I called the dealer & ask how abig block could have small block exaust. He said paperwork came with the car & " I KNOW NOTHING" then he hung up. Did anyone see the body splice on the underside.The front & back 1/2 are not the same body. OH well it's only 200,000
                      KEN 7808
                      • Larry M.
                        • December 1, 1986
                        • 541
                        Re: FLEA BAY 67.
                        Build sheet lists aluminum wheels...no mention of them on the window sticker.
                        Larry
                        • Larry M.
                          • December 1, 1986
                          • 541
                          Re: FLEA BAY 67.
                          From a paint quality standpoint, it appears as if the white stinger stripe on the hood in front of the scoop has a 'wiggle' in it on the way to lining up with the point on the headlamp panel (unless I'm viewing it incorrectly).
                          Larry
                          • Page C.
                            • February 1, 1979
                            • 802
                            Re: FLEA BAY 67.
                            Maybe the back half of the car was a small block and when they spliced the car together they did the same to the tank sticker?
                            Page Campbell
