car judging - NCRS Discussion Boards
car judging
  • Brad H.
    • August 12, 2007
    • 724
    car judging
    You that have had your cars judged is the procedure to be there before they say and stay at the site for the two or three days continually with your car maybe for ques. and answers or can you enter your car then leave the site and return when the event is over, wouldn't want to do that fear of damage and uncaring to your car, but another situation may have to be dealt with at the same time in that location Bend Oregon Sept 11-13 meet. Thanks for the help Brad
  • Dick W.
    • 10483
    Re: car judging
    The Judging Reference Manual addresses issues such as this. The owner must be there to sign all the paperwork at check-in and the judging sheets at the time of judging. Someone else could drive the car to the meet and remove it at the end.
    Dick Whittington
    • Harmon C.
      • August 31, 1994
      • 3228
      Re: car judging
      Brad
      You need to be their to check your car in and put it on the judging field or the staging area for the operation check. The day your car is judged you must be with your car till the judging is completed on your car. If staging is done for operations you must be their at that time also for operations and the move in at some meets.
      Lyle
      Lyle
        In addition to what Reba says...
        the NCRS Judging Reference Manual defines other owner obligations during a judging meet and it's worth reading BEFORE you arrive and go through the Flight Judging process 'cold'. There should be NO surprises!
        Your car is also there for display purposes (many attend just to walk about and see the cars). Therefore, you're expected to remove protective covering(s) in the morning (even if your car is NOT being judged that day) and replace them at the end of the day.
        When the day comes for your car to be judged, YOU are expected to put it in 'standard judging mode'. That means remove any covers, remove any non-factory items (floor mats, Etc.), raise the hood, extract the spare tire and associated jacking components and so on. Any tools required for these tasks are your responsibility to provide.
        Bottom line, knowing ahead of time who does what/when/where (responsibility of owner + responsibility of judges) is a good idea!
        • Chuck S.
          • April 1, 1992
          • 4668
          Re: car judging
          If you're worried about security, that's generally not an issue.
          The Judging Reference Manual may cover this, but if you don't have JRM, all cars parked in designated parking will generally have contract nightime security provided by the sponsoring chapter.
          In the case of judged cars, they are in some cases (unfamiliar with Bend, but I doubt it will be indoors) locked inside the display building. This is both a blessing and a curse; if judging is indoors; it's great for the judges because it's climate controlled, but it makes owner use of the car very difficult, if not impossible. Even outdoors, you can expect restrictions and controls on your use of the vehicle, but security is generally not an issue...you can sleep at night.
          • Brad H.
            • August 12, 2007
            • 724
            Re: car judging
            Thank you all for your valued responces, it is highly appreciated. Brad
