Deck lid bracket openings - NCRS Discussion Boards
  • scott scearce
    Hi all,
    I had a couple of questions for anyone that may know. On my '60, where the bracket frames come out of the car and then attach to the deck lid, there are two good sized retagular openings. These opening are located in compartment the soft top folds into and on the back side of this compartment. I had a couple of questions regarding this opening.
    1. Are these openings so oversized compared to the actual size neccesary for the bracket frame because of the power soft top option and the opening was needed for that?
    2. I have looked around for something to seal up the opening except for the space needed for the bracket arm and have not seen too much around. Anyone had success in finding something functional/looks moderately good for this? I thought this might help reduce any odors coming through the opening.
    Thanks a lot!
    Scott Scearce
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Deck lid bracket openings
    Can you post pic.??
    • Roy B.
      • February 1, 1975
      • 7044
      Can you post pic.??
        Scott -
        The openings are quite a bit larger than is actually required for hinge clearance - that's normal.
        It's unlikely that you're getting any odors from the trunk - they're coming from the fuel tank compartment and its opening into the underbody area behind the driver's seat.
          Scott -
          • scott scearce
            Thanks for the feedback.
            Scott
            • scott scearce
              Scott
              • Verle R.
                • March 1, 1989
                • 1163
                Scott,
                I attempted to send email and it bounced with this message:
                host onemain-mx.earthlink.net [209.86.93.122]:
                550 tazi@jps.net...User unknown
                Please update your profile with a good email address.
                Thank you,
                Verle
                • Verle R.
                  • March 1, 1989
                  • 1163
                  Scott,
                  Thank you,
                  Verle
