1972 - LT1 --idle
  • Jerome E Pederson
    1972 - LT1 --idle
    The idle on my car after running the car for 15 to 20 minutes or at least until the engine coolant reaches 180 degrees, drops to 300/400 RPM's and really struggles to stay running without working the throttle The carb has been rebuilt by Holley and is the correct carb for the car. The car is equipped with A/C. However, with or without the A/C running this idle problem happens.
    Once the engine cools, from not running, The engine will idle properly both the initial fast idle and then the normal idle at 800RPM's. Then after driving it for 10/15 minutes the engine will struggle to idle without working the throttle.
    Any help or thoughts.
    Jerry
