plug wire brackets/carburetor insulator/t.c.s. - NCRS Discussion Boards
  • robert leazenby
    My car has most of the original big ticket items but is missing some of the little things that would make it complete.
    My car is equipped with a radio and I have the shielding for the plug wires but am missing some of the brackets, clips and grommets for the plug wires. Are any of the above deleted for a car equipped with the shielding. Specifically should my car have the brackets that mount on the bell housing mounting deck at the back of the block, and the brackets and clips for the front wires 1,2,3and 4.
    My engine is equipped with the holley and I am looking for the original type insulator that mounts under the carb. Is this made of gasket type material or do I need to also install gaskets under/above or both? I believe the part # is 3972156. Is it still available?
    Also my tcs equipment is all but long gone. I have located the harness wiring that goes to the solenoid, relay, and temp switch. What I don't know is where the relay and temp switch were originally installed (1970 LT-1). The dimples that the AIM shows were never drilled out on my car so I am thinking there was a change at some time. My vacuum relay for the wiper door is also in a differnt location, it is mounted on the firewall near the master cylinder, not on the passenger fender as shown in the AIM.
