1968 front wheel hub assembly - NCRS Discussion Boards
  • james Kekeisen
    Is there any difference between the right and the left front wheel hub assembly, having cleaned them up I can't tell which is which and they seem identical?
    Thanks, Jim
    Re: 1968 front wheel hub assembly
    James-----
    The front rotor/bearing hubs are the same for either side. The spindles (steering knuckles) are the same for either side.
    The parts that are specific for each side are the steering arms, brake caliper bracket, and disc brake dust shield.
    • james Kekeisen
      Thanks Joe, after fighting the spring and control arms for a few hours and completing one side I started to panic that I was going to have to take it apart again.
